How to create vertical scroll bar for window
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello everyone I have created a window using  hwt::CreateWindow win
I have added only one row now to reduce size of Quote. Number of rows in actual script are in loop so my number of rows sometimes exceeds 100. So I need scroll to window.
So how can I add scroll to it
And I seardched for  hwt::CreateWindow win help for all pther commands help is easily available in HM  help but I didnt find any help related to these commands, So anybody direct me to proper help for hwt commands and specifically  hwt::CreateWindow win
proc ::compQuery::window {} {
    variable str_slave;
    variable str_master1 '';
    variable str_master2 '';
    variable str_master3 '';
    variable str_master4 '';
    variable str_master5 '';
    variable str_master6 '';
    variable str_master7 '';
    variable str_master8 '';
    variable e1;
    variable e2;
    variable l1;
    variable l2;
    variable e3;
    variable l3;
    variable e4;
    variable l4;
    variable e5;
    variable l5;
    variable e6;
    variable l6;
    variable e7;
    variable l7;
    variable e8;
    variable l8;
    variable ang_incr;
    variable def_val;
    set dlgWidth  [ hwt::DluWidth 100 [ hwt::AppFont ]];
    set dlgHeight [ hwt::DluHeight  250 [ hwt::AppFont ]];
    set min_dlgWidth  [ hwt::DluWidth  250 [ hwt::AppFont ]];
    set min_dlgHeight [ hwt::DluHeight  200 [ hwt::AppFont ]];
    hwt::CreateWindow win \
        -minsize 200 100\
        -maxsize 2000 2000 \
        -noGeometrySaving \
        -geometry ${dlgWidth}x${dlgHeight} \
        -cancelButton Cancel \
        -defaultButton Cancel \
        -acceptButton Accept \
        -minSize $min_dlgWidth $min_dlgHeight \
        -acceptFunc '::compQuery::GetcompVar' \
        -cancelFunc '::compQuery::Cancel_func' \
        -windowtitle 'Stress contour capture script' \
        -post;
    #Create recess to hold frames
    set recess [hwt::WindowRecess win];
    grid columnconfigure $recess 1 -weight 1 ;
    set l1 [::hwtk::label $recess.l1 -text 'Evaluation criteria for Max principal stress:']
    set e1 [::hwtk::entry $recess.e1 -width 200 -takefocus 1 -help 'Entered value is max limit above this shown as grey colour' -textvariable  ::compQuery::str_master1];
    grid $l1 -row 1 -col 0 -sticky w -padx 4 -pady 4;
    grid $e1 -row 1 -col 1 -sticky e -padx 4 -pady 4;
    #default value $recess.e1 set 315;
    hwt::KeepOnTop win
1 - 12 of 121
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    There is no option to scroll a toplevel
    You have to use text box or canvas widget to do it
    Another way, use package BWidget which has tk classes to create scrollable frame and toplevel
    Altair Employee
    OP
    Hello tinh
    do you have any example for these suggested method and which one will be best to use in current case
    User: "tinh"
    Updated by tinh
    Hi
    This is usage of bwidget scrollable frame
    http://wiki.tcl.tk/1091
    Altair Employee
    OP
    Hello,
    I studied some help on web now I am able to get scroll bar but not able to fix content in  between scroll bar
    Now I am doing trial and error to get final out come
    mean while can anybody look at my script and suggest improvement
    namespace eval ::compQuery {
        variable ang_incr;
        variable def_val;
        variable str_slave;
        variable e1;
        variable e2;
        variable k1;
        variable k2;
        variable k3;
        variable k4;
        variable k5;
        variable k6;
        variable l1;
        variable l2;
        variable e3;
        variable l3;
        variable e4;
        variable l4;
        variable e5;
        variable l5;
        variable e6;
        variable l6;
        variable e7;
        variable l7;
        variable e8;
        variable l8;
        variable ang_incr;
        variable def_val;
            -minsize 200 100\
            -maxsize 1000 100 \
            -noGeometrySaving \
            -post;
        set types {
            {{H3D File}      {'.h3d' }        }
            {{OP2 File}      {'.op2' }        }
            {{All Files}             * }
        set z [tk::listbox $recess.z -yscrollcommand '.ss set' -xscrollcommand '.s set' -height 5 -width 20]
        set y [ttk::scrollbar $recess.ss -command '.y$ yview' -orient vertical ]
        set x [ttk::scrollbar $recess.s -command '.x xview' -orient horizontal ]
        grid [set z] -column 0 -row 0 -sticky nwes;
        grid [set y] -column 1 -row 0 -sticky ns;
        grid [set x] -column 0 -row 1 -sticky ew
         for {set j 1} {$j <= 4 } {incr j} {
        insert end set l$j [::hwtk::label $recess.l$j -text 'Evaluation criteria for Max principal stress:']
        insert end set e$j [::hwtk::entry $recess.e$j -width 200 -takefocus 1 -help 'Entered value is max limit above this shown as grey colour' -textvariable  ::compQuery::str_master1];
        insert end set k$j [::hwtk::label $recess.k$j -text '****']
        $recess.z grid [set l$j] -row $j -col 0 -sticky w -padx 4 -pady 4;
        $recess.z grid [set e$j] -row $j -col 1 -sticky e -padx 4 -pady 4;
        $recess.z grid [set k$j] -row $j -col 2 -sticky e -padx 4 -pady 4;
        hwt::KeepOnTop win
    proc ::compQuery::Cancel_func {args} {
             catch {destroy .win};
    ::compQuery::window
    User: "tinh"
    Updated by tinh
    Hi,
    This is a sample using textbox as scrollable window, that you don't need to care about scrollbars
     set w .myToplevelWindow ::hwtk::toplevel $w -title 'Sample scrollable window' pack [::hwtk::text $w.t -width 80 -height 25] -side top -fill both -expand 1 pack [::hwtk::frame $w.f] -side top -fill x pack [::hwtk::button $w.f.btnCancel -text Cancel -command ::p_btnCancel_Invoke] -side right -anchor e pack [::hwtk::button $w.f.btnOK -text OK -command ::p_btnOK_Invoke] -side right -anchor e set f $w.t.text.f $w.t.text window create end -window [::hwtk::frame $f] for {set i 0} {$i<100} {incr i} {     set lbl [::hwtk::label $f.lbl$i -text 'label [expr 1+$i]']     set ent [::hwtk::entry $f.ent$i -width 20]     grid $lbl $ent -row $i }
    Altair Employee
    OP
    Hello tinh,
    I am running your script in HM 12.
    Received following error
    Error : Unknown option '-title'
    User: "tinh"
    Updated by tinh
    Please upgrade to hm13 or 14 or 15
    Altair Employee
    OP
    ohhh.....ok
    Thank you
    User: "Jouher_20929"
    Updated by Jouher_20929
    Hi,
    Can you modify this, so i create a  subframe inside which is scrollable. @tinh
    User: "tinh"
    Updated by tinh
    I think above sample is very clear,
    Frame 'f' was scrollable and you can pack anything in it
    @tinh i have list of check box inside the frame. I have to make it scrollable.
    User: "tinh"
    Updated by tinh
    Put that frame in text widget like above sample
