How to create vertical scroll bar for window
hello everyone I have created a window using hwt::CreateWindow win
I have added only one row now to reduce size of Quote. Number of rows in actual script are in loop so my number of rows sometimes exceeds 100. So I need scroll to window.
So how can I add scroll to it
And I seardched for hwt::CreateWindow win help for all pther commands help is easily available in HM help but I didnt find any help related to these commands, So anybody direct me to proper help for hwt commands and specifically hwt::CreateWindow win
proc ::compQuery::window {} {
variable str_slave;
variable str_master1 '';
variable str_master2 '';
variable str_master3 '';
variable str_master4 '';
variable str_master5 '';
variable str_master6 '';
variable str_master7 '';
variable str_master8 '';
variable e1;
variable e2;
variable l1;
variable l2;
variable e3;
variable l3;
variable e4;
variable l4;
variable e5;
variable l5;
variable e6;
variable l6;
variable e7;
variable l7;
variable e8;
variable l8;
variable ang_incr;
variable def_val;
set dlgWidth [ hwt::DluWidth 100 [ hwt::AppFont ]];
set dlgHeight [ hwt::DluHeight 250 [ hwt::AppFont ]];set min_dlgWidth [ hwt::DluWidth 250 [ hwt::AppFont ]];
set min_dlgHeight [ hwt::DluHeight 200 [ hwt::AppFont ]];hwt::CreateWindow win \
-minsize 200 100\
-maxsize 2000 2000 \
-noGeometrySaving \
-geometry ${dlgWidth}x${dlgHeight} \
-cancelButton Cancel \
-defaultButton Cancel \
-acceptButton Accept \
-minSize $min_dlgWidth $min_dlgHeight \
-acceptFunc '::compQuery::GetcompVar' \
-cancelFunc '::compQuery::Cancel_func' \
-windowtitle 'Stress contour capture script' \
-post;#Create recess to hold frames
set recess [hwt::WindowRecess win];
grid columnconfigure $recess 1 -weight 1 ;
set l1 [::hwtk::label $recess.l1 -text 'Evaluation criteria for Max principal stress:']
set e1 [::hwtk::entry $recess.e1 -width 200 -takefocus 1 -help 'Entered value is max limit above this shown as grey colour' -textvariable ::compQuery::str_master1];
grid $l1 -row 1 -col 0 -sticky w -padx 4 -pady 4;
grid $e1 -row 1 -col 1 -sticky e -padx 4 -pady 4;
#default value $recess.e1 set 315;
hwt::KeepOnTop win
