Dear All,
could you please tell me how can i get a specific displacement whenever i apply pressure inside the cylinder in radioss block?
i mean how can i stop applying pressure at specific displacement?
example:
when i apply pressure inside cylinder i don't know how much deformation i get.
i give X amount of pressure and i want displacement 1 mm and after that displacement the cylinder will goes to the initial diameter(0.5 mm) after some time.i want specific displacement at X amount of pressure.
could you please tell me how to apply displacement sensor in radioss block?
can i use this displacement sensor in this application?
is there any other way to get specific displacement when we apply pressure inside the cylinder in radioss block?
Thanks a lot.....
Best Regards,
Bhautik
