I am attempting to run an optimization using Optistruct but the solver keeps outputting the following error:
*** ERROR # 312 ***
In static load case 1
the compliance is negative or large 1.7638e+015.
Optimization/buckling analysis cannot be performed.
due to possible rigid body mode.
INFEASIBLE DESIGN (AT LEAST ONE CONSTRAINT VIOLATED).
From what I understand, this error could be from a model that is not fully constrained or from poorly defined materials properties. My model is constrained with 2 RBE3 elements so I believe my constraints are not the issue and I don't understand what could be wrong with my material inputs.
I have attached my model for reference. Any help would be appreciated
Thanks
