I am performing stress analysis of component assembly having a solid block and a shell plate connected to each other.My question is what is the difference between stress(t) and von-mises ?
Von Mises stress is used to check whether their design will withstand a given load condition, that is if a given material will yield or fracture.
Stress(t) is the stress tensor results. There are many open web resources available on this topic and I recommend you to go through the same.
Stress tensor also having vonmises ?
The tensor results that are computed in HyperView is available in the Help Menu and the same is attached along for your reference.
QUE: Why and when do we go for stress (t)?
The tensor results is a description about what happens in one direction due to the happenings in other directions. As an example, sigma_xx is the stress acting in the x direction due to a force acting in the x-direction. Similarly in other directions also.
For Von Mises in tensor is calculated using principal stresses (please go through the document shared in the last reply), and there will be some variation in scalar and tensor values.
We normally check for scalar values.
sir i did please see.
