I'm experimenting with the composite skateboard tutorial. I changed the loadcases but kept the maximum displacement contstraint of -2mm. After the optimization there is a maximum displacement of 2.049E+00 mm. Is there a possible reason for violating the constraint? Or could it just be devoted to rounding numbers?
Many thanks,
Jan
