Realizable K epsilon
Altair Forum User
Altair Forum User
Hi all
For using Realizable K epsilon Turbulence model .If i use  intensity and viscosity ratio
What will be the optimum value of  below said parameters for Internal flows
Turbulent velocity scale =
Turbulent viscosity ratio =
  • Altair Forum User
    Altair Forum User
    edited September 2017
    Hi Dinesh,
    Turbulent velocity scale : is the average velocity at the inlet
    Turbulence viscosity ratio: viscosity ratio, \frac{\mu_t}{\mu}, is the ratio between the turbulent viscosity, \mu_t, and the molecular dynamic viscosity, \mu.
    The turbulent viscosity ratio is directly proportional to the turbulent Reynolds number. Typically, the turbulence parameters are set between 1 to 10. here viscosity ratio 10 is good enough.
    Regards
    Ravi Harti
Welcome!
Welcome!
