Hello Everyone
I have made a dogbone shape for tensile test analysis. Since the material is anisotropic, I used converse software to map the fiber orientation. As you can see in the model attached, on one side of the dogbone, there is a rigid, in which master node(1) is completely fixed and on the other side there is enforced displacement on the master node(2).
I want to create a graph where I obtain displacement of the master node(of the displaced side, 2) vs. reaction force of the other master node(fixed side, 1). I am doing a non linear quasi static analysis.
First, I tried to plot displacement vs time and that functions looks correct but reaction force vs time graph gives me just a point. I don't understand why it just shows a point and not a line like it does for 'displacement vs time' graph. I was planning to do cross plot once I obtain the reaction force vs time graph.
Some additional information: master node on the fixed side has id number: 7833 and master node on the displaced side is 7834
Would appreciate any help
Thanks in advance
