Dear Community,
I am running a free-size optimization with a quite complex model and the run is aborted after a number of iteration for the ERROR 703.
I receive the following message:
Error in input data - Lower bound larger than upper bound44879 0.100408E+01 0.100000E+01 Error in input data - Lower bound larger than upper bound44882 0.100408E+01 0.100000E+01 Error in input data - Lower bound larger than upper bound44897 0.100408E+01 0.100000E+01 Error in input data - Lower bound larger than upper bound44900 0.100408E+01 0.100000E+01 Error in input data - Lower bound larger than upper bound44918 0.100408E+01 0.100000E+01 *** ERROR # 703 *** number of design variables = 47541 number of constraints = 37 error code from optimizer = 900 The optimizer failed to find a solution of the optimization problem at the current iteration. This error occurs in module 'appdrv'.
Other information:
If I change design parameters, the iteration where I have the error also change.
If I remove ply drop-off constraint, the error disappears.
If I reduce the design domain, the error disappears.
(unfortunately, I cannot share the model)
Any idea on how to solve this issue?
Thank you in advance,
Alessandro
