Hello everybody,
I have a general question regarding radioss block.
Is there a convenient way of running subcases of one model? Like in radioss bulk or Nastran one can easily define different SPC and Loadset combination and have them solved in sequence.
It seems with radioss block this function is not directly implemented.
So the question is, how else could it be done?
Basically, I have a random prismatic strucutre, that I want to load in compression and shear.
From what I understand, I have to do two completely seprate *.rad files and run the simulations seperately. I guess I could somehow do it in batch mode as well, but is that really it?
What I eventually want to do, is running a material identifiction in HyperStudy. Therefore I would ideally have the results of both load cases (compression AND shear) in the same results file.
But I havent managed to do this.
Is there a way to achieve this?
regards
