I have performed a simple non-linear quasi static analysis to study a ball-plate contact. Optistruct was used as a solver. Contact is modelled as node to surface, slide contact.
I am wondering why Contact Traction (Normal) is resulting in a very high number? As far as I understand, Contact Traction (Normal) is supposed to represent a pressure in a contact.
In such a simple example (ball-plate contact) it is easy to verify the results with analytics, which in fact yields more than 100 times smaller values for the contact pressure in comparison to the Contact Traction results.
As a 'workaround' to plot the contact pressure, I am checking Element Stresses, where the option Pressure is chosen (I have CONTF card enabled in a solver). The results are correct here.
Could you please give me more insight of what Contact Traction is representing? I haven't found anything in a Reference guides.
Thank you in advance,
Matej
