I'm doing an explicit analisys, so in block110 format, with composite material, using Law25. I would like to know how to evaluate a safety factor with the output of stress obtained from the following instructions:
/ANIM/SHELL/FAIL
/ANIM/SHELL/TENS/STRAIN/ALL
/ANIM/SHELL/TENS/STRESS/ALL
With them I look the failed layers or the stresses ply for ply (VonMises, P1major etc...); I would like to know in which direction inside the element is calculated the stress and compare it with a my max ( before the plastic strain like in isotropic material with the Rp0.2) to create a SAFETY FACTOR. Probably is a wrong approach...can you help me about this topic?
Thanks
Bruno
