I would like to know if there is a possibility to perform a Plastic Analysis for a control arm in my suspension system. I would like to visualize stress and the average extension of the flexible body
@riham1994
You need to make the control arm as flex body. You can view these tutorial on how to make a body flexible and use the same in MotionView/MotioSolve
i've already did this step for the elastic analysis, so it's familiar to me... An another question: for the results the average extension of the flexible body is available or not ?
I am sorry, I did not understand your question. Can you please elaborate?
Right now there is no way you can do a elastic-plastic flexbody simulation using MotionSolve.
That's exactly what i want to do is a plastic simulation using MotionSolve. there is no alternative way for this simulation ?
MV/MS has new NLFE feature to simulate Nonlinear FE analysis through MotionSolve, but right now cable and beams can be modeled with this.
I will check if there is a better way to do this using MV/MS.
