Hi there,
My simulation shows ' Error in TH
No restart file'
How do I add this?
Please check the TH field.
If we create a data file using TH/NODE and we did not define the title by mistake ...then the job errors out.
Please share the complete .out file to understand better.
Thank you Prakash,
Please find the .out file attached below.
Thanks in advance.
Surya
Hi Prakash,
I made the changes and the simulation is running now.
If anything shows up, I will let you know
The simulation ran successfully, but there is no . h3d file generated. Where to get it from.
Also is there other way by which we can access results, there are following files which were generated.
From the out file I see that the frquency of animation file is zero.
Please use ANIM/DT in Engine and provide a frequency to write out animation file(s).
Hello Prakash,
I ran the analysis in hyperview, but the car(component - part 1) seems to go through the guardrail (component - rail). It seems there is nothing happening between the contacts.
What have I done wrong please guide me.
Thanx
Also Prakash one more thing,
I have students version of Hyperworks which doesnt allow separate Radioss application I guess.
Is there a way to assign more threads to simulation.
I used to do it in the radioss application window earlier when I had the full version.
Also Prakash one more thing, I have students version of Hyperworks which doesnt allow separate Radioss application I guess. Is there a way to assign more threads to simulation. I used to do it in the radioss application window earlier when I had the full version.
No, this is one of the limitations with SE.
Regarding the simulation, there is no contact between the barrier and the car.
Please create contact between the car and the barrier and try again.
thank you so much,
The simulation was successful
