Hello there,
basically I am doing an analysis of our brake disc for formula student in radioss. So far the structual part works and the energies look fine.
The next step is to get the thermals in there.
In the documentation for the type7 interface there exist an Fheat. But I can't find it in Hypermesh.
So my Question is whether the enegry transformation into heat is working or not if only I_the is activated.
Another strange problem I am facing at the moment is that if i define a starting temperature in Ti and T0 (~300 K) the results still show me 0 K.
By the way I am using Block 120 because on the cluster only 120 is installed.
Looking forward for some help.
