Hello Friends,
I made a ¼ symmetric 3D model for composite L-shaped structure to investigate the delamination behavior. The setup was as follows:
1) The unit: t-mm-s-MPa, Time: 1.2 s, Time frequency: 0.0012s, /AMS was used to reduce computation time. The velocity of the impactor is 20mm/s,
2) Interface Type 7 was used as contact, Igap= 0 to keep constant gap as same as Gapmin= 0.05.
3) Since I wanted to simulate delamination fracture process, I created Mat/Law 14. In the card, σt3 =55.6 MPa which is same with interlaminar tensile strength measured by the experiment,
When I checked the results of stress Z and Displacement-force curve as shown in attachments, the following disagreement with experiment was found:
1) According to the time-stress curves by creating /TH/BRIC/ card , when the maximum Stress Z is 44.28MPa , the delamination fracture behavior has occurred, however, σt3 is 55.6 MPa in the model. So what should I revise?
2) It takes me 2 days to calculate (workstation, options: -nt 64), but the oscillation still happened (The velocity of the impactor is 20mm/s), so how to modify the model that I can get the smooth curve by balancing the computation time and accuracy of results?
Besides, the force became zero after delamination because of separation between impactor and L-shaped specimen, however, in the experiment the force is not zero after delamination, so how to solve the problem?
