hello,
I want to read rigid body forces in the radioss ( Hypercrash), how can i get this results?
Best,
Sara
Hi Sara,
To get the forces for the rigid bodies you need to put it in time history. /TH/RBODY/thgroup_id. To perform the same in HyperCrash, select the rigid body>>right click and select data history>>yes.
In HyperGraph, select the T01 file from which you can plot the rigid body forces.
Hi @George P Johnson
Adding /TH/RBODY/thgroup_id. will help to readout the overall force extracted from the Rigid body node ?
Using /TH/RBODY you can extract the results in that rigid body elements.
If you want for that master node create a /TH/NODE output block for that node.
Please go through the Help menu on /TH/RBODY and /TH/NODE where all the outputs extracted are shown.
Hi ,
I have created output block /TH/NODE for the master node of the rigid body. But it is showing error as no variables has defined.
Once the output block is defined give the variable number as 1 and put DEF as the variable so that all default outputs will be extracted.
Thanks and now its working fine. For TH/RIGIDBODY we are getting force at 3 directions. The resultant force was not mentioned at the output. How can i calculate/convert the same ?
For /TH/RBODY you will get TF in results which is resultant force.
