Spring connection for suspension arm assembly
Altair Forum User
Altair Forum User
When i tried to perform quasi-static analysis of a front suspension with a flex body within spring connection between meshed parts, i have the problem as shown below:
'Static analysis terminated because absolute Max_delta_q_tol is satisfied.
ERROR: GTCMAT Initial Static Analysis failed!
ERRMES:USER [1]
Error computing Compliance Matrix for wheel center markers.
** EXECUTION STOPS DUE TO ENDFLG IN USER SUB **
WARNING: Statics analysis failed at time = 9.500E-01
WARNING: Statics analysis failed at time = 9.500E-01'.
And the h3d static ride analysis of the supension isn't available. i think that the problem comes from spring connections between meshed parts because i already have done this case with rigid connections.
i'm really waiting for your reply.
  • Altair Forum User
    Altair Forum User
    edited April 2017
    @riham1994
    Can you share the .log file?
    BTW, I am still working on your full vehicle model :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
  • Altair Forum User
    Altair Forum User
    edited November 2020
    Check your file transfert link :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Altair Forum User
    Altair Forum User
    edited May 2017
    @riham1994
    Thank you for sharing the files. I will check and update to you soon.
  • Altair Forum User
    Altair Forum User
    edited May 2017
    @riham1994
    I think the problem is due to redundancy. Get rid of this redundancy during modelling and try again. Try to write out animation files at every iteration/step (you can use output options in Run panel to change output settings of H3D file).
  • Altair Forum User
    Altair Forum User
    edited May 2017
    I didn't get you, which redundancy are you talking about ? otherwise could you show me step by step what to do
  • Altair Forum User
    Altair Forum User
    edited May 2017
    i used template model in this case to make sure that the problem comes from the flex body and yes i have the same problem
