[RELEASE] : VKL::vDynamicLoader::vDynamicLoader -- Load library error : 126
[RELEASE] : VKL::vDynamicLoader::vDynamicLoader -- Could not open library : VisREBase
Hi Ilia Minkov,
May I know what is the type of the CAD file you are using?
Hello Ilia Minkov,
This error message is thrown by Third Party library – Spatial which we use to import CATIA models. This does not affect the import of the CATIA.
We have already informed Spatial to fix this issue. Kindly ignore this error until we get the fix.
Thanks & Regards,
Santhoshkumar
Hello Ilia Minkov, This error message is thrown by Third Party library – Spatial which we use to import CATIA models. This does not affect the import of the CATIA. We have already informed Spatial to fix this issue. Kindly ignore this error until we get the fix. Thanks & Regards, Santhoshkumar
i have the same problem there is any solution
Hi Ilia Minkov, May I know what is the type of the CAD file you are using?
for me is Autodesk Inventor Assembly (.iam) INVENTOR
