Good night,
   I'm new to the Altair Flux (student version) and I'm trying to find the magnetic field strength or magnetic flux between two permanent magnets that are separated by a 8 millimeter gap and the upper and lower inner faces between the gap are North and South respectively. I can draw the geometry, but I have difficulties when I define the physical properties of both the magnets and the infinite box. I have tried solve, but I still can not interpret well, nor obtain the magnetic field intensity at the central point between the permanent magnets.
   I'm using NdFeb N52 neodymium magnets.
   Attached image of the model.
 Where can I find a tutorial that can help me with this kind of problem. I've already looked at Flux's help examples, but they were not enough. Could someone describe the step-by-step here?
   Grateful,
   Cleber Gobira
