I'm new to OptiStruct and I'm attempting to analyze a 2D linear elastic problem. I've utilized the CQUAD4 shell element, which has 6 degrees of freedom per node. Is there another shell element option that only has 2 degrees of freedom per node?
Additionally, could you provide instructions on how to switch from a 5-point integration scheme to a 4-point integration scheme, if it's feasible, while using the CQUAD4 element?
Thank you,
Anoop
