Hello, I'm new here so greetings to all of you.
I need to simulate the behavior of a cylinder-shaped fluid mass contained between two plates ,within a hollow cylinder (like illustrated in the figure attached). In particular, I need output data about the pressure field within the fluid due to the application of a huge force/pressure on one plate so that the whole system accelerates within the hollow cylinder at tens of thousands of g's. The other plate reacts to the motion only with its inertia, so that after a transient phase there is a steady state condition in which the distance between the two plates is fixed, for given initial data.
I actually don't know if it is feasible with any software of the Altair suite, and I would appreciate an hint on how to proceed.
I am trying to set this up with acusolve but I am having some troubles because of the absence of an inflow/outflow. Usually the examples that I found have that kind of configuration.
I'm sorry if I have posted to the wrong section.
Thank you in advance!
