After the import of a step-file in simlab, the existing bodies are not named like expected.
I have bodies that are all named '_Final_Parts'. This also happens if i import the CATIA-File.
If i import the same step-file in hypermesh, the names of the bodies are correct and that names I would like to have in simlab after importing.
Do you have a solution for that?
Regards
C.
