I asked the quesiton to forum last week and after the answer and links i got, i still have some question.
It's been said draw direction constraint can be used to integrate the constraint to topology optimized design which will be manufactured by selective laser melting,
Should i apply the parameters as; Single draw (because the plate moves only one axis) and click the "No Hole" box to avoid enclosed volumes.
Thank you for taking time.
