   I have to model a coil with the resistance of 2Ohm. How can I realize it? The Application is 'transient Magnetic 3D'. In the Editor for a non meshed coil i can define the reistivity of the coil. But I only know th resistance of it. I can't use the formula resistance=resistivity*length/A because I don't know the length of the wire.
   In the circuit Editor conextI use a coil conductor. There I can define a resistance.
   Is this the same?
   Thanks.
