Hi, I have been getting this error and I have referred to other comments here as well, I have constrained my boundary constraints with respect to rotational dof well. I have one rbe2 element connecting the two components. Is it possible for anyone to tell what could be the actual problem?? I have attached the output file.
The compliance is negative or large 1.44361e+008.
The rotational displacement has a large magnitude, -183.872 degrees (larger than 180).
The rotational degree of freedom may not be constrained properly in the model.
subcase id = 1
grid id = 31
component = 5
