In the video attached, you can gain insights into freely optimizing designs using topology optimization while simultaneously considering electromagnetic (EM) and mechanical constraints. Explore method to optimize without predefined parameters and uncover novel topologies that integrate structural and magnetic considerations seamlessly. This helps enhance your design optimization and discover new avenues for pushing the boundaries of electromechanical engineering.
