Design of Steel Structures using KDS 14:31 - 2017 code
Matthew_Sauer1
Matthew_Sauer1
Altair Employee
edited August 2024 in Altair HyperWorks
In this video we will look at the code checking and design of steel structures using S-FRAME's Steel Design workflow. For more details on Steel Design with S-FRAME, check out this playlist: https://www.youtube.com/playlist?list=PLGNemB0NFb0De14pFVyhv1gW7TLh3x5O1 You can also find training material for S-FRAME here: S-FRAME Training
