Standard Traps vs Floating Traps
Baba_Majekodunmi_703
Altair Employee
edited May 2023 in Altair RapidMiner
Standard Traps
  • Work Vertically by Column
  • Assume Consistent or Regular Data Placement in a Report
Floating Traps
  • Work Horizontally Across each Line
  • Can Account for Inconsistent or Irregular Data Placement in a Report
Welcome!
Welcome!
