In this article, we will discuss what to do when S-FRAME loads with a black screen. This is related to a corruption of the initialization file data, and is very easy to resolve.
This behavior will manifest itself as shown in the images below:
Open Structure Window:
S-FRAME Visual Editor Window:
Since the menu bar is still visible, you can go to the Options menu->Colors and Fonts… and select the ‘Defaults All’ button to resolve the matter. If this step does not fix the black screen, please open a support case with our team via the Altair Community.
