Rubber Seals are widely used in many industries to prevent leakage, contamination, etc. In this model, the seal is made of rubber and modeled with hyperelastic material. The analysis aims to examine the stresses, strains, and contact forces during the assembly.
For more information, please, refer to the attached Presentation and Model & Results.
