In this video, we introduce the EMI Design Suite which debuted with PSIM 2021a. With the design suite, you can design an EMI filter with a click of a button and then test your design with pre-set or custom EMI standards. This tool can be used for power supplies and motor drives. With version 2021b we have expanded the capabilities of the design suite by adding 3-phase functionalities, expanded filter types, and more examples (e.g. Vienna rectifier).
