In this video we go over the steps to perform a steel code check in S-STEEL. Simply select the desired sections (or a group of members), and proceed with the code check according to the design code of interest for different Load Cases/Load Combinations.
View the Code Check Utilization Ratios (with the Colorized Legend displayed) and access the report results after a code check.
