Lets take a look at some of the important new and improved capabilities in the HyperGraph new interface.
Table client has been migrated to Qt
Plotting from HG while solver is running
Color by file, axes and layer as well as multi window support
Using Stackmath to Edit Curves
Use Cora and ISO to plot correlation metric between test and CAE
Filter out maximum and minimum contributors from the displayed curves.
Access all template level actions, channel checking options and auto fill options in the main UI.
LsDyna Reader enhancement to match binout and ASCII file TRC's.
The HyperWorks Command (HWC) language records playback workflows in HyperView and HyperGraph, together with the handling of Sessions Report templates. Tasks performed in the browser, panels, or graphics area are recorded in a simple and intuitive syntax in the command history window below the panel.
