The goal of these videos is to go over an Air Spring FMU that was constructed in Activate and used in an Rear Suspension in MotionView.
Attached are the model files used as well as an slideshow on how to set up the AirSpring FMU in MotionView.
Creation of FMU in Activate
AirSpring in MotionView
