Aligning a model's shell coordinate systems is important for pre and post-processing. Shells with different local coordinate systems can complicate model loading, and viewing of the analysis results. This tutorial explains
how shell coordinate systems are defined
viewing results relative to the global or local coordinate system
viewing the local shell coordinate system and reversing shell modifying them
