This document helps in setting up a model for Failsafe Design. A model which is in use in critical locations have to be failsafe proof.
A failsafe structure must support 80-100% limit loads without any catastrophic failure. This method enables users to come up with failsafe designs that don't fail even when a pert of it is damaged.
We have attached a sample model which is related to the images used in the document.
