Process manager helps users setup analysis with a series of step-by-step process templates. Whether you are a beginner or a pro, it can make your life easier.
These process templates prompt you to enter unit or generic engineering data, and once the data is available, automatically create frequency response analysis loadcases and associated solver cards. The below is an example for Random Frequency Response Analysis.
