This tutorial shows how to use SimLab to design and run electromagnetic analysis with Flux solver for electric motors. The studied device, a brushless DC motor with surface permanent magnet, includes the following elements:
In this tutorial, three typical transient magnetic analyses are defined to evaluate the motor performance:
Note: The geometry model is built by the Sketch of SimLab
All files corresponding to this example are accessible with this link (for different version) :
Step to follow :
