In this Tips, Tricks, and Inquiries demo we take a look at the Match tool and Instances functionality in HyperWorks 2021.1. These tools complement each well when organizing and meshing models with repeated parts.
In this video we will:
Create part sets of similar parts using the Match tool.
Use Instances to create links between identical parts and speed up meshing.
