Simulation Files and tutorial PDF download link
SAG Mill Breakage Tutorial Overview
The simulation shows the breaking of larger rocks due to impacts and grinding of smaller particles.
- Specification of mill dynamics (rotational movement)
- Creation of breakable materials
- Creation of dummy particles
- Set up the Tavares breakage model parameters
- Set up appropriate timestep
- Analyze the results through the Analyst
- Using the Breakage postprocessing tool
Model Overview
Semi-Autogenous Grinding mill with Breakage
Please check the video tutorial below:
Duration
Setup - 20min
Simulation - 2-3 hours
Analysis - 15min
For further EDEM learning material please see the following links for tutorials , e-learning, training and How-To videos:
And for further information and latest updates please see the Altair EDEM Community page:
