SimLab Tutorial: Steady State Heat Transfer Analysis
Learn how to:
- Create different materials with thermal properties for the cylinder, fin and insulators
- Create steady state heat transfer
- Apply tie contacts between the bodies
- Define thermal loads such as flux and convection
