SimLab Tutorial: Linear Transient Heat Transfer Analysis
Learn how to:
- Split faces using chaining edges
- Create a transient heat transfer solution
- Create material with thermal properties
- Define initial conditions
- Apply thermal loads such as time dependent heat flux and convection
- Define solver settings and analyze
