SimLab Tutorial: Non Linear Static Analysis - Flex Plate
Learn how to:
- Apply symmetry constraints
- Apply enforced displacement constraint
- Create 3D bolt with pretension
- Create advanced contacts
- Create loadcase
- Modify solution parameters
- Solve and review the results
