SimLab Tutorial: Solver Setup for Thermal Steady State Analysis
Learn how to:
- Create material and apply properties
- Create user-defined contacts
- Apply thermal loads and define loadcases
- Define lines static loadcases with the temperature leadcase included
- Create proper solver settings for each loadcase
- Export and solve for multi-physics analysis
