Editing and Debugging Python Scripts for use as Process Automation Tool with Other Products
Presentation by Kamalraj Rajagopal, Senior Application Engineer at Altair.
Using a realistic example involving Python as the scripting and process automation tool used by Altair SimLab, learn how to use Compose to create and debug Python scripts.
