In this webinar discover all the capabilities of the Altair pre-processing tools to handle real complex cases with Flux. In addition we explore the powerful features of HyperMesh allowing you to to defeature, modify and manage your complex assemblies. We also explore the various functionalities in SimLab which will allow you to easily mesh large problems.
