This article is an overview of how to run CADFEKO [LEGACY] in 2022.3.
CADFEKO has been refactored to include an improved graphical user interface, effective workflows and many new features.
For users that still want to use CADFEKO [LEGACY], it is still included in the Feko 2022.3 installation.
Note: CADFEKO [LEGACY] will be removed from the Feko 2023 installation.
To make CADFEKO [LEGACY] the default when launching CADFEKO, use one of the following options:
Note: To revert to using CADFEKO 2022.3, click the Use Legacy CADFEKO button again.
Set the environment variable: FEKO_LEGACY_CADFEKO=1
