Implementing Field Weakening & MTPA Control with PSIM
Advanced Functionality of the Motor Control Design Suite. The motor control design suite takes your motor drive system parameters and generates a stable and working motor drive simulation. The output can be edited to suit the designer's needs and particular application.
