HyperWorks CFD Known Issues
Below is a list of known issues that were discovered after release. (Note: This article will continuously be updated when issues are reported)
HyperWorks CFD 2021.2
1) Volume mesher creates negative jacobian elements
2) FE geometry remesher creates very skewed elements
3) Fe geometry remesher destroys ids of the surfaces
HyperWorks CFD 2022.0
